sparky 134
- Joliet, IL
I have an industrial customer who is looking to replace his 1000w MH high bays with 10 lamp T-5's. Does anyone know of a manufacturer who makes a 10 lamp T-5 ?
I've also seen a very bad example of replacing MH with T5 high bay. They basically had to go back and double the number of T5 lights.
So I'm kind of skeptical about a 1 to 1 replacement for a 1000W fixture. I doubt the T-5 will have the coverage the high bays did.
I would suggest carefully running the calcs with a simulation software and making sure you aren't getting really dark areas even if you do find a 10 lamp fixture.
Paragon Lighting is one of probably several manufacturers that have a 10 lamp T-5.
http://www.paragonlighting.com/
They should also be able to provide basic lighting simulations for you to check that the new lighting would be adequate. But from what I have heard, a 10 lamp T-5 is generally a 1 for 1 replacement for the 1000W MH.
The most I've seen are 6-lamp T5HO ... but they provide quite a punch.
What kind of facility? Do they really need that much light?
The 6-lamp fixtures, mounted at 20'-0" above the floor and spaced 15'-0" on center provided an average of 87 footcandles in a school gymnasium I just ran calculations on.
This is a food manufacturing facility. The current 1000W MH fixtures are spaced ~48' o.c.
That's a lot of light! How high is the ceiling?This is a food manufacturing facility. The current 1000W MH fixtures are spaced ~48' o.c.
