jaiken@trane.com
A water chiller has a manufacturer supplied UL Listed unit mounted compressor motor starter with a 100% rated circuit breaker as its supply connection. Can this circuit breaker be used as the 440.12(A) required disconnecting means or does a separate disconnect sized to 115% of the nameplate rated load current need to be added? The rated load current of the compressor motor is 1119 and the circuit breaker is 100% rated at 1200 amps.
