1000 amp DC breaker
TheJed
Hello all,
Please see the attached picture of this 1000 amp breaker that was installed in an open frame as part of a -48vdc plant.
It does appear to have a plastic shield of some sort over the exposed lug connection points.
Does this approach align with the NEC code for mounting breakers?
I am concerned this is a safety issue.
Thanks for any input.
Jed-
petersonra
Northern illinois
engineer
Hello all,
Jed-
I don't recall there is anything in the code about how to mount a breaker. That would be a design consideration, or a UL listing issue perhaps.
Is 48 VDC considered hazardous where this is installed?
Is it otherwise guarded by a fence or locked doors, or some other effective physical means?
Is it under the control of a utility?
What makes you think it might be a safety issue?
personally, i would be most concerned about whether there was an adequate fault clearing path. I can't tell if there is one. A battery string can put out a LOT of current.
qcroanoke
Sometimes I don't know if I'm the boxer or the bag
Roanoke, VA.
Sorta retired........
I would say being 50 volts or less gets you some relief but I don't know how much as far as guarding and protection goes.
