BackCountry
- Southern California
- Licensed Electrician and General Contractor
I’ve seen a few topics on 1000v DC disconnects, but none that mentioned this product quite yet.
Siemens makes a 1000v DC disconnect, single circuit (see line diagram). Looks like a standard 3 pole AC disconnect, and they route the positive conductor through all three poles to get the rating.
It’s a big unit for a single circuit.
I have a ground mount with four arrays, 9 strings, and while the stamped drawing does not show a DC disconnect leaving each ground mounted array — I sure would like to have disconnecting means. It doesn’t look like that’s going to be possible though, at $1000/each and no lead time from two suppliers.
Of course there’s a DC disconnect at the SMA TriPower inverter, just not physically exiting the array itself.
I suppose we’ll just have to transition into conduit in a 3R box. Which brings up the which wire to use in conduit question — I guess we’ll have to use PV wire the whole way.
