mylk100
- Philadelphia
- Electricians helper
I am removing a 60 amp sub panel and installing a 125 amp main lug only panel. I have to change out the wires, the panel and the breaker feeding the sub to 100amps.
Mind you, I have material that I'm using from the scrap. I have a 3 individual #2 al or 3 individual #3 cu that I can use. The main sits in a garage on a wall and the sub is directly next to it. Could I use any of these wires to wire a 100 amp or do I need to go higher? I understand I also need a ground. What is the smallest ground needed? I do have left over #8 cu so I'm hoping to use that up. Thanks for everyone chiming in.
