I need some clarification please. I am going to install a disconnect for an HVAC contractor. The disconnect will feed a 10kw heat strip, which by code is a continuous use application, so I will be using 6 awg wire and a 60 amp breaker. But the 10kw heat strip got me thinking about the type of disconnect I need. Are all non fusible disconnects able to handle a continuous load from a 10kw heat strip? Is there a wattage limit on disconnects? Am I over thinking this?
