Correct me if this wall is made of cement blocks, but I'm reading (poured) concrete.Imagine a concrete wall that was supposed to be three inches thick. The electrical design shows some branch circuit panels surface-mounted onto this wall. All conduits (incoming power and branch circuits) will be entering from the top.
Now imagine that the concrete wall contractor made an error, and began to make the wall nine inches thick. The error was noticed when the wall was about 3 feet high. The rest of the wall, from that point to the ceiling, was built 3 inches thick. As you stand inside the room, and look at the wall, you see the wall coming up from the floor, then it recedes six inches, so that there is essentially a 6 inch lip (upon which you can set your coffee cup).
Who's to say that this 6" flat strip isn't a raised step of the floor.
I think anyone with a lick of sense would call that a jog on a wall not a another floor level.
No, the situation is real, though it did not arise in the way I described. What actually happened is that the concrete contractor started constructing the wall of the electric room about six inches away from where it was supposed to be, making that side of the room 6 inches smaller, and giving that space to the room on the other side of the wall. The error was discovered after some of the wall had been built. Rather than tear down what was built, they just built a wall where it was originally supposed to be. That left an extra thick wall for the bottom few feet, and left the shelf space directly under where the panels are supposed to go.I believe Charlies intent when starting this thread was to point out the deficiencies in the wording of this section.
I was thinking floor level even before I got to Al's post, but my thought was about building a platform, space permitting, at the same height as the ledge (not a 30" deep counter). You could then argue the platform is the floor.I think anyone with a lick of sense would call that a jog on a wall not a another floor level.
