petersonra
- Northern illinois
- engineer
Interesting that it would be code legal for the sewer water to drip on the electrician working on the pb, as long as it did not drip on the pb.If so there is no violation.
That is correct. The pipe is not directly over the panel. It's probably 2" out of the panel footprint.I can't tell for sure from the picture but it looks to me like it is in front of the PB, not above it in the dedicated equipment space.
not a problem DennyLet's be real
Then there is no issue. The pipe is not within the dedicated equipment space and is above the 6'6" minimum height for the working space.That is correct. The pipe is not directly over the panel. It's probably 2" out of the panel footprint.
"Code is codeIs it hurting anybody? Is it ever likely to get in the way of somebody working on the equipment? Since the answer to both of these questions is no, what is the purpose of the rule in this case other than an arbitrary rule that just gives inspector something to nitpick about.
