A
a.wayne3@verizon.net
Guest
Senario,a/h/u in a closet not within sight of panel.There is just enough room in the closet for the a/h/u and the disconnect is on the side wall.The door can open 90 degrees but the space surrounding the disc.does no way come close to the required working space height width or depth.110.32 states that unless allowed in the code.If there are no energized parts as written in 110.32,then does working clearance need to be maintained?A breaker lock out would take energized parts out of the senario.Regardless as to the fact of it being used,being there would be code compliant.IMHO this would negate working space clearance.
