12/4 need to be derated?
Thank you all for the clarification.
The load will not be over 20 amps.
I will be powering two instances of 3000 watts/240V baseboard heaters. My plan is to run 2 20 amp lines. There are 3 wall mounted tstats. All my wiring to tstats & baseboard will be coming down from attic space.
Using the 12/4 will give me a little more space in the wall boxes for my tstats.
Thanks again.
iwire said:
LOL :)
It is in the code, 'only count the current carrying conductors' (my words)
BTW ... If you keep holding my feet to the fire I will have to ban you. ;) :) JK
Iwire it looks like a lot of people are holding your feet in the fire. Keep up the good work, it looks like it is usually in fun. At least if do it is .:smile:
