Re: 12 wire motor termination
Stew is correct for a delta connected motor. But dont confuse a delta supply to mean that the motor is delta also. You might have a delta supply but the motor might be wye connected. if wye then the hi or 480 connection would be series connection for 12 lead delta is 4&7 tied and taped,5&8 tied and taped,6&9 tied and taped, 10,11,12 tied and taped and Lines to 1,2,3.For 240 volt 4,5,6,10,11,12 tied and taped. Line 1 to 1 and 7, line 2 to 2 and 8, and line 3 to 3 and 9. Two speed motors can have 12 leads brought out. Anyway the real fun comes in when some of the lead markings get lost. The main thing here is to look at your motor speed, horsepower and amp ratings and wiring diagram before you do your connections. NEMA MG-1 2003 Part 2 pages 27 thru 33 show these standard conections.
