Can i feed a 120/208v,3p-4w from a 120/240-3p-4w distribution board?
raider1 Senior Member Staff member Location Logan, Utah Jan 20, 2010 #2 Can you elaborate? I am not understanding your question. Chris
mivey Senior Member Jan 20, 2010 #3 BCE said: Can i feed a 120/208v,3p-4w from a 120/240-3p-4w distribution board? Click to expand... If I understand what you are asking, I'm thinking no. The neutral on the wye is the same voltage to all three phase (it is really a neutral for all three phases). The neutral for the 120/240 is only a neutral for the 120/240 legs. It has a different voltage to the high leg.
LarryFine Master Electrician Electric Contractor Richmond VA Location Henrico County, VA Occupation Electrical Contractor Jan 20, 2010 #4 BCE said: Can i feed a 120/208v,3p-4w from a 120/240-3p-4w distribution board? Click to expand... Only with a 240D-to-208Y 3ph transformer. You can feed a panel, but the voltages will not be 208/120.
