Volt-Amps
- Indianapolis
Regards,
I have a load calculations question:
1. Incoming service voltage is 120/240, high leg, 3 Phase.
2. But all my loads are single phase (bldg with 4 residential units).
3. I populate the panel schedules (A, skip B, C, and so on).
4. Since column B remains blank with 0 loads, I end up with total load on A and C legs.
5. Now when I convert kVA to Amps, do I divide by Sq. Rt of 3 (1.732), even though it's high leg, no 3 phase loads and nothing on B leg?
Thank You
Thank You
