meternerd
- Athol, ID
- retired water & electric utility electrician, meter/relay tech
Are you even sure that it's a 4W Delta service with a "center tapped", grounded winding? Seems strange they wouldn't run a neutral. If it doesn't have a center tapped 240/120 transformer in the bank, you'll have to get a neutral wired at the transformer bank. That may involve the POCO. If it's a corner grounded Delta, you've got even bigger problems. Maybe I just didn't understand all of the posts, so if my comments are stupid, forget it....I won't be offended (much).
