120 VAC Wall receptacles fed from UPS
To explain, I'll install two old-work boxes with NM between them, put a recessed receptacle behind the TV, and a power cord through a blank plate with a 1/2" hole, wire-nutted to the NM.
The cord can be plugged into either the same power or suppression strip as the rest of the A/V system, or into a nearby receptacle. I usually get the power cords from cheap power strips.
