Naterade21
- Virginia
Putting in the 125/250 4 wire inlet also allows for easier integration of a larger generator down the road - but consider a 30 amp instead of a 20 amp inlet, if/when they decide to go bigger they probably go to something with 30 amp output receptacle.
Although the mains are switched off at the breaker while the generator is activated with interlock activated, the neutral in these systems is un-switched and still shared with the upstream neutral power line, correct? Would this not pose a hazard to power line workers working on lines, or are they safe / unaffected? Going based off this rough illustration: http://www.interlockkit.com/typicalinstall1.htm
