FoxValleyRob
- Sugar Grove, IL
I'm confused about how to connect a 120V emergency generator into a normal power distribution system. I see in the wiring diagram that in order to obtain the 120V (NOT 240V), they have jumpered the line side of the circuit breaker together. That means that you would have to read 0V on a meter from L1 to L2. This is on the emergency generator side. The problem I'm having is that when you measure the same leads (L1 and L2) on the NORMAL side, you'll have 240V. When the transfer switch goes to emergency, the only way I see this working is that the phase of one of the lines has to switch 180 degrees. What happens to a load when it suddenly sees a 180 degree shift in its voltage? If I'm way off here, please let me know...
Thanks a bunch!
Thanks a bunch!
