We had a contractor install a filtering system which has a single phase 3/4 hp pump. The control panel, which is a small 12" x 12" pull box, has only a push buttom start/stop. There is no means on disconnecting the supply voltage other than the supply breaker which is located on the other side of the plant.
Doesn't this fall under Art:430.102?
Thank you and Merry Christmas.
