Greetings all I was sent to troubleshoot some 12V lighting track, it was installed about 7-8 months ago and has been burning thru lamps.
Its your typical low voltage halogen, two exposed aluminum bars are the voltage rails.
The track is working, and has no dimmer. The owner has the correct lamps 20W MR-16 but they are burning out in a month or two. Recently they also tried LED's
They observed the LED's to flicker and burn out one by one in a few days.
I have troubleshooted this kinda things before and its usually a dimmer issue, so I was thrown off by the no dimmer.
Then I took all the lamps out but one 20W halogen when I went to measure voltage between the two rails I only get 1-2 volts.
I would expect 12.
From each rail I get 10V to the metal case of the power supply.
If I put all the lamps in or take them all out still the same reading.
I checked my meter to make sure it was working, scratched the aluminum still 1-2 volts.
Then I used a different meter, still same reading.
Checked at the MR-16 socket still no voltage, but the 20W halogens were on and full brightness.
What am I missing here? how can the lamps be working with no apparent L-L voltage?
I would expect 12.
