Shumake
- Denver, CO
Me again, not sure if this is the right place to post but has anyone dealt with terminating 13,200v lines in a pad Xfmer? What type lugs are used?
Why do you say "none" for the lugs question?None
And you can't do it without training.
As I recall most of the Burndy lugs are rated for use to 35kV.
As far as training for the installation of the stress cones, that is required in some areas, and often by the contract documents. However, an electrician that can read and follow directions should have not issues installing a 15kV stress cone.
Best idea if you have no experience with this.Thank you, everyone. I'm here to to discuss and continue education with everyone else and appreciate your input! We are not here to butcher or endanger anyone but to follow proper protocol, which in this case may be subbing these connections out to someone qualified and experienced in medium voltage.
They have them, just not as common.I have never seen a pad mount that did not use plug in elbows for the HV. Of course I have not seen it all.
I agree. It is not rocket science but it is not as forgiving as a run of the mill termination so should be approached with due caution.However, an electrician that can read and follow directions should have not issues installing a 15kV stress cone.
Knowing this is a forum, it would be wise for you to take anybody's recommendation with a grain of salt. Don't believe everything fed to you. Verify from qualified people you know if things said here are the right ones.
I should share with you my personal experience where a friend asked me for the order no. of a 3M cold shrink termination kit for a 24kV install which I gladly gave. For whatever the reasons, he bought a 3M kit with similar order no. but with a different last digit/s. To make the story short, it was a failed install, The terminations blew like his crew were in the midst of a gunfight! As much as we wanted to help out, something at the back of our minds tells us to warn others about how simple things can go awry, even with a single digit difference.
If the OP wants to 'go for it' maybe they can, we will not and that sounds like a very bad idea.
I don't recall using any special tools for 5 and 15kV termination kits where the cables have connection lugs. I haven't done an elbow connection in a long time, but I do recall a special tool to remove the semi-conductor.I agree. It is not rocket science but it is not as forgiving as a run of the mill termination so should be approached with due caution.
It also requires special tools that would be silly to buy for one job.
Most of the industrial transformers around here don't use the elbow connections, but they are not really pad mounts....that being said, I think it is even easier to install an elbow termination than a termination for a lug type connection on medium voltage systems.I have never seen a pad mount that did not use plug in elbows for the HV. Of course I have not seen it all.
Agreed. I would not recommend doing this without training and the proper cable strippers. The bad thing about MV terms is that if done wrong they won't fai immediately but rather 12 months down the road.I agree. It is not rocket science but it is not as forgiving as a run of the mill termination so should be approached with due caution.
I suppose you could hack away at it with a pocket knife but I wouldn't recommend it.I don't recall using any special tools for 5 and 15kV termination kits where the cables have connection lugs.
Yes, that is one tool. Of course the semi-con also has to be removed in a similar manner when installing a lug termination.I haven't done an elbow connection in a long time, but I do recall a special tool to remove the semi-conductor.
The strippers and semi-con tool make for a clean job of it. Training is preferred of course but the instructions today are detailed enough that someone with proficiency in other cable terminating skills should be able to make a good termination.Agreed. I would not recommend doing this without training and the proper cable strippers. The bad thing about MV terms is that if done wrong they won't fail immediately but rather 12 months down the road.
