IllinoisContractor
I know that EMF is an issue in conduit installations. You must have at least 2 conductors in a pipe where the current is flowing in opposite directions. (Hot & Neutral. Hot & Switch Leg, Neutral & Switch Leg, etc.) Is EMF an issue with Romex? Can you use 14/2 for travelers or do you need to run 14/3 where you have 2 travelers and a hot/switch leg?
Thanks.
Thanks.
