#14 gauge aluminum wire
mannyb
Florida
The current code book doesn't reference a breaker for #14 aluminum wire. Does this mean you can't put a breaker?
It's probably not #14 aluminum if it's old. More likely it's tin coated copper that looks like aluminum. Do you have any photos?
Ill see if I can get some pictures. The breaker panels has 15s and 20s OCPD. The wire straps and breaks like aluminum. You can visibly see the difference between the both. You could also be right.
