I posted and asked if a receptacle from 15 amp circuit could be installed in a bathroom if the required receptacle on a 20 amp circuit was there. The answer was yes.
Same question about a laundry room ?
Required laundry recept circ recept is there.
Minor work on a different wall with an existing receptacle on a seperate 15 amp circuit that has to be moved a couple feet.
Can I install that receptacle on that 15 amp circuit? Or do I need to tie into the 20 amp laundry circuit?
While we are at it ....
Let me ask the same question if it were a kitchen outlet and the two appliance were there.
Thank you
Thank you
