Question, I'm writing a SOP to lock out a arc furnace and we have a 15 KV cap bank associated with it. Ths SOP calls for the caps to be discharged. The cap bank has a shorting switch that connect the bank to ground to discharge the caps. We are debating if a visual inspection of the stabs making a grounded connection is adequate or should we have the electricans use a high voltage DC meter to measure for any charge.
My personal opinion is to test the circuit with a meter, but the electrical folks are resisting as checking with a meter would require PPE and typically the area is over 100 deg F.
I would appreciate your thoughts or comments.
