AV ELECTRIC
My son is having a 8kw solar system installed . . He has a manufactured home with a 100 amp sub panel that the solar installers want to use to put there 40 amp breaker in . I thought the panel is to small for this size system but they said they have some sort of controller to prevent overload but I would think this would limit what the solar system would be allowed to produce making this size system not worth paying for . There is one power wall that they said helps .
My thought if possible is upgrading that 100 amp sub panel to 150 amp . There is a 200 amp pedestal where the 100 amp sub is fed from . I think it's a Siemens pedestal and was installed in 2007 ( sorry not much info ) . Now they don't make a 150 breaker for that situation unless maybe a quad which would not work as only 2 spaces are available . The other 2 are used for the well pump house sub panel .
Now is there alternative ? Maybe adding some lugs and do a direct feed to the 150 amp main breaker sub panel . I presume the wire would need to be sized for 200 amp if that could be done . No experience with solar except for putting in breakers for a new system . It seems hokie to put a 8kw system into a 100 amp panel
