Davebones
- North Of Tampa Fl
We have a Atlas Copco GA110 (150 hp ) air compressor installed in 1997 . Our supervisor went to start the compressor the other day and the motor shorted out . As he said he knows this is the 2nd time he's known ( not sure how many times before its seen a short ) of a short in the motor I have a concern about the breaker " LH36300 300 amp " feeding it . Know that they are only rated for so many hard shorts . Right now there is only a 200 amp ( 125 hp rated ) non-fusible disconnect at the compressor . I started to look at changing the non-fusible disconnect to a fusible disconnect with the idea we could coordinate the fuses to go before the breaker trips . I noticed that the wire from the breaker to the disconnect is only 3/0 . I know for a 150 hp the disconnect need's to be at least 400 amp and the wire should have been 4/0 . Being this was done in 1997 and has been running this way should we consider upgrading the wire and disconnect ??
