The simple answer (that is all I can handle :grin: ) is that you can only do it if there are two or more receptacles. The theory, I suppose, is that you won't have more than 15 amps going through any one of the 15 amp receptacles. You might, for example, have 8 amps going through each of a pair of 15 amp receptacles, so that neither is overloaded, and the total load of 16 amps is still within the capacity of the 20 amp circuit.zappy said:why is this ok?thank you.
