An existing MCC w/1600A main is fed with 4 #500 per phase. Originally (site is 1970's vintage), the site motor loads (I assume) would have allowed the breaker to be sized per 430.63. Many of the original larger motor loads have since been removed, so that using 430.63 now gives an overcurrent device rating less than 1600A. Other electrical system upgrade work is now being performed on site. Would code now require either increasing service conductor size or a new breaker that does not exceed the ampacity of the existing conductors?
