175W mercury vapor
koenton
New member
Does a mv-175w light
Can anyone tell me if a mv-175w light supose to have 120 volt going in and 230 volts out to bulb?
Thanks
rwade0700
Albany, NY
Electrical Contractor
Will a MV bulb "cycle" on and off ? Customer called saying it will stay on for an hour or so, turn off, then re light. My guess is either lamp or ballast, which would be the most likely? BTW owner says lamp is about 5-6 years old. Thanks.
I have never known a Mercury Vapor lamp to cycle on and off, I just see them lasting a long, long time giving less and less lumen output until they are just emitting a small glow.
The lamp in the luminaire could be the wrong lamp for the ballast and could be cycling on and off or there could be light interferring with the photoeye if one exists.
I don't think that these ballasts have a thermal cutout either.
The easiest thing to do is to remove and replace the lamp with the proper lamp matched to the ballast and see if that makes a difference.
You could always replace the fixture with a new one, it is probably cheaper than replacing the ballast.
readydave8
re member
Clarkesville, Georgia
electrician
175w wall cubes with MH or MV lamps will cycle on & off, according to how its mounted either change ballast & capaciter or as you say the whole thing and get a new, clear lens in on the bargain.
hurk27
175w wall cubes with MH or MV lamps will cycle on & off, according to how its mounted either change ballast & capacitors or as you say the whole thing and get a new, clear lens in on the bargain.
I was thinking that only HID's with starters/igniter's are the ones that can cycle?
I know of no MV or even older MH below 150 watts that have igniter's, only HPS and pulse start MH?
hurk27
A lineman school in NE recentlyhad a trainee die from a fall while learning this pole climbing skill. We have done it from a ladder for years but more & more I start looking for a bucket truck.
Falling, sliding back down a pole and you will have wish you fell, all those little spike holes leave a nasty splinter sticking out at the top that will ripp into your skin as you slide down, no fun at all, spent a day at the hospital picking out splinters in my arms and legs after my homemade spike shoes failed about 10' off the ground years back, never again.:mad:
EC - retired
:grin::grin::grin:..sorry:grin::grin::grin:
readydave8
re member
electrician
This is what I've seen at many car washes, I always assumed that it had to do with heat and some kind of thermal cuttoff in ballast but I never did the research to find out why, I just fixed them. Usually by changing all parts that could be affecting problem. Some say that usually it's just the capaciter causing problem.
Car wash owners don't always know that their lites are cycling because they're not there all night.
Is it possible that I was wrong and that some kind of drop in voltage was making some lites go out and restart but not others? (at 20-30 different locations).
kwired
Electron manager
NE Nebraska
EC
Ignitors provide the pulse need to start the arc and have nothing to do with the arc being extinguished other than the fact they will be called upon again to restart the arc. HPS lamps cycle near end of life because they draw more current the more hours they have in run time. This current eventually becomes more than the ballast can supply and the arc is extinguished when the current falls below what is needed to maintain the arc. The lamp cools a bit and the cycle starts over.
kwired
Electron manager
NE Nebraska
EC
If voltage drops below level needed to maintain arc in the lamp the lamp will go out. If voltage returns to high enough level the lamp will restart - after the pressure in the arc tube falls low enough to allow starting. With HPS this can be as little as a minute or so, with MH it can be 10 minutes or more. I think PSMH are closer in time to HPS.
stevebea
Southeastern PA
Pulse Start Metal Halide 1-2 minutes hot restrike.
