hbiss
EC, New York NEC: 2017
- Little Falls, New York NEC: 2017
- EC
A smaller pulley on the motor should do it. 1440 RPM@50Hz / RPM@60Hz.
-Hal
-Hal
You think ? I was guessing a 'capacitor run' judging by the 8 MFD capacitor, It would create a 90 DEG out phase winding. Not sure if its run or start.Cap start AC induction motor...
Permanent split capacitor motors only uses one cap and it stays in the circuit the whole time the motor is running, so it's like a running cap. It also means you can vary the speed of the motor. I don't think I'd worry about it in your case. Is the mixer really gonna care about a few hundred RPMs faster?You think ? I was guessing a 'capacitor run' judging by the 8 MFD capacitor, It would create a 90 DEG out phase winding. Not sure if its run or start.
