JLottes
- Gaithersburg, Md
I have run across a situation that has me puzzled.
In 1995 a single family dwelling had a heavy up from a 30A 6 Circuit fuse box to a 200A 24 circuit breaker panel. Panel itself installation was completed & was signed off on by a Master Electrician & an Inspector.
Problem: I found that whoever installed the wires in the panel had put 8ft to 10ft romex "pigtails" to metal junction boxes in the attic. Some of these junction boxes were closed off & marked, some left open, some unmarked and buried in the blown in cellulose insulation. Some of these connections were made without the benefit of a junction box at all. I know this is not Code & not my question. The Romex pigtails were wire nutted to "Old type" BX wire. The rest of the house is wired with the Old BX, except where I've found & replaced it. 3 Circuits so far.
So my questions are:
In 1995 was the "Old style" (Fabric & Rubber insulation, not plastic) BX allowed to be cut back to a pliable insulation spot & put back in service, or was it supposed to be removed from service if disturbed?
If this were your job would you bring this to an Inspectors attention?
What about the Electrician?
Thanx
Clear Dark Skies
John
39.138274 -77.168898
Thanx
Clear Dark Skies
John
