djy2000
- United Kingdom
Hi
I'm trying to calculate the required cable for a rural property(25kW/50kW peak). The property is 1km from the local transformer and is currently supplied by a 3phase 220v cable but this is shared by a number of properties and is subject to significant voltage drop. I see 2 solutions to this
1. We can run our own overhead cable(1km) to the transformer but by my calculations an aluminium cable would have to be very thick in order to support a < 10% voltage drop
2. We can run a underground high voltage cable and buy our own transformer but i imagine this would be very costly.
I've been told that some of the neighbours use up to 50kW but the cables dont look thick enough to me. So I can only assume either I've got my calculations wrong or they dont mind the significant voltage drop?
Also if their is a high voltage drop would this cause a high neutral voltage? (assuming unbalanced 3 phase)
Can anyone provide some advice?
Thanks
Derek
Thanks
Derek
