But your issue is with the hood, correct? The cooktop is a seperate issue altogether, just like the refrigerator & microwave & flat screen tv. I usually put the hood on the gen'l lighting circuit.MRI said:.....no, the cooktop is gas.....
All it says is "supplemental equipment and lighting." That does not imply that the supplemental equipment must be operating whenever the range is operating.jamesoftn said:Doesn't Exception 2 to 210.52(B)(2) pertain to the receptacle for the gas equipment such as the electronic lighter? Not the lighting in the hood/fan. I do not believe this exception pertains to the hood as it is a seperate piece of equipment as the range can operate without the hood.
MRI said:Gas cooktop with an electric oven below.
do most of you just wire the hood fan into a the kitchen lighting ckt. or even a general lighting ckt.? I don't think a dedicated ckt is needed.....
I think 422.16 (B) (4) (5) is looking ahead to the day that the vent fan will be replaced with a microwave.
220/221 said:We now have to put vent hoods on a dedicated 20 amp circuit here in AZ. I assume it's because of the microwave factor.
480sparky said:Do they also require a 50a 120/240 circuit if there's a gas range? 1 30-a 240v circuit in case they want to install an electric water heater or clothes dryer later? The list of possible future electrical loads is far too long to try to 'future-proof' the wiring.
I never liked the "What if game".....What if the HO decides to plug a _____ into there? What if the the hanger hit a wire? I think we should wire it this way because what if.........After I here a couple of what if I reply with something like " What if a Helicopter wants to land on the roof, should the carp reframe the roof? Do you think they will need any power up there? I think will be safe with 100a subpanel..What do you think?480sparky said:Do they also require a 50a 120/240 circuit if there's a gas range? 1 30-a 240v circuit in case they want to install an electric water heater or clothes dryer later? The list of possible future electrical loads is far too long to try to 'future-proof' the wiring.
electricmanscott said:A gas hood fan???![]()
