jasonc267
- Philadelphia
I am trying to feed (2) 3 way switches and another sigle pole switch using one feed coming off a run of high hats.. I have double gang box at the bottom of the stairs. In that box I have the stairwell 3 way and the living room 3 way. So the wires that enter that box are a 14/3 to other 3 way switch for living room, 14/3 going to the top of the stairwell 3 way switch. The feed a 14/2, that is homeruned at the first high hat out of 6. Then I have a 14/2 that goes to the den single pole switch. I am pretty sure I will need to take out the dens 14/2 and run a separate feed to that light. All of these lights are on the same circuit. Also the 14/3 that goes to the other liv room switch is in a double gang box next to front door. In that double gang box is a single pole switch for the exterior lights. Can i get a feed for the exterior lights off that 14/3? and can I feed the stairwell lights off of that single feed coming from the high hats homerun? Thanks
