bubbarhd
- Lynnwood, WA US
How is 2 hour protection defined? How is 2 hour assembly defined? Are they the same?
I have low volt wire runs for smoke control that require 2 hour protection. Is a wire run inside a 2 hour assembly considered 2 hour protected? Technically it's in the middle of a 2 hour wall, say a stairwell wall. But as I understand it, being in the middle means it is only 1 hour protected from fire from either side. Is the code calling for 4 layers of drywall all the way around my wires to obtain 2 hour protection or CIC rated wire?
Sent from my SM-N910V using Tapatalk
