Hi guys. We are looking at adding a sub panel to a garage for a client. LONG story short, we cannot get from the main panel to the garage with substantial damage. The meter base is located on the wall of garage. What is the proper way to power the sub panel off of the meter base?? I was thinking of adding a splice box under the meter base and and splicing the 2 feeder cables into the wire coming off the meter lugs. Will I need a disconnect under the panel or is the splice box ok by itself? The combined loads will not exceed the meter base rating. Please cite the NEC if there is anything that can help me do this or anything the is against code with this situation. Thanks a lot!!!
