deb4523
- Alaska, USA
I'm sure this has been discussed somewhere on this forum, but I can't seem to find any previous threads.
I would like to use a 2 pole 20A breaker for a split wired duplex receptacle - one phase to one outlet, one phase to the other outlet & share the neutral and ground. Essentially, I need two separate 20A outlets, but would like to minimize expenditures, because I need to do this many times for head bolt heater outlets in parking lots.
Is there any code against doing this? I don't think it qualifies as paralleling...
Also, would I be able to have a 15A load on each of the outlets simultaneously, or would that trip the breaker? I'm not sure because each of the loads would be on a different phase, but it is still one breaker. :?
As always, thanks in advance for your expertise!
