2" pvc slb
Dennis Alwon
Chapel Hill, NC
Retired Electrical Contractor
I have always heard them called service LB's -- thus the SLB. I also have not seen them in pvc but that doesn't mean they aren't out there.
220/221
AZ
I think the S would be a problem.
I always thought it was short LB since they are shorter than LB's
If you need a standard PVC LB, no problem. Even the Dome Depot has them.
If you have space restrictions, use a JB and drill it.
Beware of wire bending radius if applicable.
don_resqcapt19
Illinois
retired electrician
What would you use it for? Even an standard 2" LB is probably too small to put the wires in if this is for a service.
Dennis Alwon
Chapel Hill, NC
I have never used them for a service but I have used 1/2" slb because they are smaller and a bit tidier. Of course I was using small wire-- #12. I can't imagine 3/0 copper in these.:grin:
220/221
AZ
Electron_Sam78
Palm Bay, FL
I guess I'm outta luck.
It will contain 4 #2 THHN and 1 #4 RHW. 2" conduit is upsized for this application so I wanted to use a smaller profile LB to stay closer to the surface of the structure
