Buck Parrish
- NC & IN
I don't use URD very often . I am estimating a horse barn. The guy wants a 100 amp panel. He even went as far to upgrade his home service to 400 in preperation to go to 100 amps for the barn.
So this would be a feeder from his home panel. That dis - allows 310. 15b
I told him the ampacity of #2 has been reduced to 80 amps.
Am I right ?
Do you have to use the 60 degree column with direct cable. I know lots of states still allow it on a 90 due to the fact thier on the 05 code.
Which is right in NC under NEC 08? Is it 80, 90 or a 100 amps. Thanks in advance.
Am I right ?
