supernibs2000
New member
- Solon, OH, USA
My company has a system that taps directly off of the power pole and is contained in a metal box on the pole. The tap is less than 5 feet and in most cases only Line and Neutral are brought into the box. The L-N connection goes through a surge suppressor/filter and then attaches to a transformer which steps down the voltage 10X. This reduced voltage is rectified and converted into 12 V for the system. Other configurations of this module uses a solar panel instead of an AC line tap (still on a pole).
My question is in regards to safety and grounding... Is there an applicable NEC section that deals with this type of system? There wouldn't be multiple ground loops and in most cases, there isn't a ground wire run into the box. Would this box be agnostic to ground fault currents? Should there be an Earth ground attached to the box (in either configuration)?
My gut tells me that there should be a good ground on any metal box hanging out on a telephone pole and that the system (as a 2-wire system with galvanic isolation) is inherently agnostic to L-G or N-G disturbances, but I could be wrong there. Looking for some direction from folks with more experience than me
Thank you for your time!
