20/5 stranded waterproof wire availability
marmathsen
Seattle, Washington ...ish
Electrical Contractor
I'm looking at redoing someone's deck railing lighting and I'm having a tough time finding appropriate wiring for the project.
The lighting is waterproof RGB+White LED tape by Solid Apollo and requires 5 conductors. Unfortunately I talked with them today and they only have 4 conductor waterproof cable.
So I'm looking for 5 conductor waterproof cable that ideally is 20 AWG stranded, but I might be able to make 18 AWG stranded work in a pinch. Anyone have any idea where to find this? A link would be great if possible.
This product was specked in before I was brought in. I'm open other product suggestions if anyone has some. The LED tape gets installed into a recessed channel (specifically designed for LED tape) on the underside of the railings.
Thanks in advance
Below are some links to the products
4 conductor cable (would work if it was 5 conductor)
https://www.solidapollo.com/transparent-rgb-wire-cable.html
RGB+W LED tape that is specked in
https://www.solidapollo.com/Waterpr...ylight-White-Quadchip-5050-72W-LED-Strip.html
