Jcomeaux21
- Lafayette la
5 boxes x 8 luminaires x 1000 watts = 40,000 watts
Assume 90% power factor and 92% ballast efficiency
Gives 48,309 va
At 208, if balanced would be 134 amps per phase (48,309/(208xsqrt3))
Given a 200 amp panel, assume continuous loading, you have 160 amps capacity.
Therefore, you have 26 amps 3 phase 208 available for additional continuous loads.
From my understanding you dont take the lamps wattage into consideration. It's the ballast it self correct?
