Mikemayo
- Northwood,Nh,USA
Here's the scenario, 100 amp pull out fused meter feeds a 200 amp auto transfer switch which feeds a 100 amp breakered Panel. Obviously a 200 amp ATS feeding a 100 amp panel is a clear code violation BUT, because the 200 ATS is fed by a 100 amp meter with fused disconnecting means, does the eliminate the need for a 200 amp ATS breaker altogether, thus allowing the 200 amp ATS to act almost as a non fused disconnect?
I'm sure this is an easy one for the Mike Holts army of electrical Genius
