200 Amp Meter Base
Just 200 amps, per leg, voltage doesn't matter other then don't exceed maximum voltage which should be 600.
One note:
Not all meter bases that are 200 amps are rated at 200 amp continuous. Mainy a residential are only 160 look at the label. If it is a meter combo it will have a 200 amp main.
Just like many Resi 400 amp are only 320.
