200 Amp Residential Meter Mains W/ copper buss
Hv&Lv
Engineer/Technician
GE, Siemens, Eaton...
maybe I’m missing the question...
MBE2040PV200BTS
copy and put that in your search engine, it’s an Eaton.
tortuga
(44.057116, -123.103394)
field supervisor
MBE2040PV200BTS
I am looking for a Meter with a Main breaker only with copper buss to feed an interior panel.
I checked the Siemens 'Speedfax'.
All Siemens meter mains are aluminum buss.
SQ D catalog looked the same,
Eaton catalog did not specify the buss type, but the one you linked to is a copper buss trailer panel.
Ill look into those more.
Hv&Lv
Engineer/Technician
Oh Ok! I knew I was missing something.
Siemens MM0202B1200 200-Amp Meter Main Combination
this one says copper buss.
tortuga
field supervisor
Cow
Eastern Oregon
We are pretty religious about using copper bussed panels where possible.
A few years ago we noticed we weren't getting Siemens copper bussed 200A metermains anymore. I was told from our Siemens supply house they don't make them anymore.
The only metermain I've found in our area that is copper bussed still is Eaton CH. So I tried one once for an overhead service, never again. Poor design on how the wiring enters the metering compartment and lands on the lugs. I don't like chasing 4/0 AL through meter jaws to get to the lugs at the bottom....
Siemens=No
Sq D=No
Eaton CH=Yes
GE=?
wwhitney
Berkeley, CA
