Dixonchad
- Marion indiana
I have a job that is in a rural part of indiana. It has an underground 200 amp base feeding a 200 amp service rated panel mounted adjacent to 200 base mounted on post assembly free standing. I have a pole building 100 amp subpanel inside the building with a 100 amp disconnect on the exterior fed with 4 wire. I also have a barn that is the same exact way. The home has a 200 amp sub panel and also a 200 disconnect mounted on the home 4 wire as well. In summary i have a 12 space service rated panel being fed from the meter base. Then using pass through lugs i feed a 200 amp disconnect exterior of the home then to the 200 amp panel inside the home all 4 wire. I also feed 2 100 amp sub panels from the 12 space pole mounted panel. A home inspector told the home owner i can not feed that many sub panels. If my main 200 amp breaker in the 12 space pole mounted panel feeds everything downstream then the system could not possibly overload. Both barns are lights and outlets minimal load. Home heats with gas 2200 sf. We are never going to need a larger service. Are there codes that would support the allowance of feeding 2 100 amp subs and a 200 amp sub?
