200 Amp Service - 400'
bradesp
New User
Retired
Hi Guys,
Looking for some guidance on the size and type of aluminum under ground cable I need if I want to bury the cable and supply 200amp service from my house meter to a barn nearly 400 feet away. The barn has one piece of equipment that requires 240 volts (in case that matters).
I plan to use a typical residential panel in the barn... I mention that because I've read some forum posts that warn about larger cable sizes and terminating the cable into a standard load center / panel box.
Thanks in advance for your help!
I am closing this thread, in accordance with the Forum rules. This Forum is intended to assist professional electricians, inspectors, engineers, and other members of the electrical industry in the performance of their job-related tasks. However, if you are not an electrician or an electrical contractor, then we are not permitted to help you perform your own electrical installation work.
If I have misjudged the situation, if for example this project is related to your work, then send me a Private Message. If you can show me that I am wrong, and that you are a licensed electrician (or at least a licensed apprentice), then I will reopen your post, and offer an apology for the delay and inconvenience.
A reminder to all members, if you see a questionable post, feel free to report it by clicking the button at the bottom left corner of the post.
