200 Amp Service Cost
electricmanscott
Boston, MA
Charge by the amp? :confused:
How the hell can you charge by the amp?
What if you have a 200 amp service that runs 50 feet into the panel, a 20' riser, and the water main is 50 feet accross the finished basement.
Or a 200 amp service with a panel back to back with the meter, a 10' riser, and the water main right next to the panel.
Rewire
We have had easy ones and we have had the hard ones.From history I find that I send a two man crew to do any service and it gets done in a day with few exceptions.I usually bid at 18 man hours plus material with a 20% markup and permit fees.I win some I lose some.
Mr. Wizard
Texas
On a basic, no frills service with a 2" riser, new meter base, nipple to the new 200A panel, and re-terminate using existing circuit wires, upsize the ground, and a couple of LITTLE details - yeah that's $2000. Outside disconnect, remote panel location, anything else adds to that. A lot.
JohnE
Milford, MA
I can't understand charging by the amp either.
What if a customer who only needs a 100 amp service change would like to go to 200 for the heck of it. His price doubles from 1000 - $2000 for the extra $150 in material?
aline
Utah
I usually go with $10/amp on residential services.
So if I want a 200amp service it would be $2,000.
If I want a 150amp service it would be $1,500.
If I want a 100amp service it would be $1,000.
Is this correct?
I can't see dropping the price $500 to do a 150amp service.
celtic
NJ
I'm almost afraid to ask: How much to swap a panel out?
How does one calculate that :-?
By the amp?
By the difference in panel physical size?
[I know how I do it ;)]
Mr. Wizard
Texas
$2600, 1 1/2" rigid mast, 2/0 copper to 39', 1 ground rod, GFCI outlet below panel, permit, (homeline 20/40 meter combo)
I have tried to charge that, and more, with no results. I guess I should have said "my 200 amp installs average 10/amp", and no, I won't do a 100 amp install for $1000. But for me, I get $2000 for a basic sevice, and it does me well. I would certainly love to make more off of each one, but around here, it ain't happening. At what I charge, I've been called pricey, but I won't do it for less.
