Postonbones
- New Hampshire
- Electronic Repair Tech III/Electrician
A twin meter can is being used to replace a single meter can. The 200 amp service will feed the two meters ( line side). Load side of the each meter to feed two separate disconnects ( one for each meter). Question i have is when i attach the EGC to the two disconnects. Is an EGC required for the meter main also? I assume the ECG for each disconnect to the ground rod will feed back through the neutral ( line side) but i’m a little unclear. One set of rods with two ECG drops for each disconnect and no ECG drop for the meter main.
