Doc13067
- Bucks County/Philadelphia, PA USA
Hello all, this is my first post in the forum but I’ve been directed to this site many times in my searches and know you guys know your stuff so thanks in advance for hearing me. I’ve got a job in which I am tasked with running service wires from atop a pole (in Home owner’s back yard) through 2” sch 40 conduit to a meter and in to the 200a main panel and then out through a second underground pipe to a 125a sub panel. I understand I’ll need 3/0 copper or 4/0 aluminum. But do I want thhn or thwn and should the ground be #4 instead of #6?
my plan was to run a 90 at the top of the pole and fish 3 wides through to the meter and then in to the panel, install a ground rod at the pole and at the panel, and then run 4 wires from the main to the sub and obviously bind the main panel but not bond the sub panel. The reason for the ground at the pole is so Peco has the option of grounding the pole when they come out to tie my new Service wires into the triplex.
